FX data to "survive" crop
After cropping I'd like the keyframer to keep its position the same in relation to the image and not the topLeft corner!
now keyframer data becomes useless after a crop.
If a keyframer position is in the middle of a project and i crop out a smaller part of that middle, i want the new keyframer position to be still in the middle of the cropped version and not shifted to the right,
I believe its the behaviour you can reasonably expect so the current behaviour could even be considered a bug.
i want the croptool to correct the fxstack
i'd like to bump this one, as i regularly run into this issue.
so "when after cropping the "zero point" is altered i want the croptool to correct all affected values in the fxstack
so that the crop doesn't mess up all the position fx's.
the nett. result of a crop should always be that nothing changes but the pixeldimensions of the project!
