position of rotation button
furushil
Post by furushil »
Is it possible to have the rotation button somewhere else, e.g. in a custom panel?
I am working in full screen mode and would like to have it somewhere on the screen.
(I have it assigned to a keyboard shortcut but I want to have it additionally on the screen)
rotation button.png (9.14 KiB) Viewed 11035 times
Edit:
How can I reassign a keyboard shortcut to rotate the virtual disc manually? It is "Ctrl+Alt" on my computer but I can not find it in the shortcut menu :shock:
meslin
Re: position of rotation button
Post by meslin »
//Edit - I just saw in your signature that you're using OSX. I highly recommend ControllerMate...
There may be a better official response, but I'd like to suggest a workaround, if you were using Windows:
Go get AutoHotkey for free at autohotkey.com. Run it and "edit the script."
To use the 'caps lock' key to simulate the simultaneous pressing of the 'control' and 'alt' keys, you would add the following two lines to the script:
*Capslock::Send {Control Down}{Alt Down}
*Capslock Up::Send {Control Up}{Alt Up}
If you're using OSX, you can do something similar with ControllerMate (http://www.orderedbytes.com/controllermate/) which is excellent but not free ($25).
-David
furushil wrote:...
you can shortcut this but it works with fixed steps of 15 degrees
zoom: Rotate +15 (counter clockwise)
zoom: Rotate -15 (clockwise)
i have set them under A and S key and use Q to reset
Zoom: rotation Reset
i'll also check out Meslins suggestion. this Autohotkey looks like a very useful little application!
furushil
Post by furushil »
Ok, I forgot that the Alt key is not assignable. I thought I assigned the rotation to Ctrl+Alt but I guess it was like that by default.
I have assigned Ctrl+Alt to one of the buttons of my wacom pen now.
I will also give the controllmate a try later.
As far as I know you can use controllermate for free, but the amount of "controllings" is limited.
