brush - info
hellofilms
brush - info
Post by hellofilms »
I am trying to digg into the world of the settings of a brush. There are really a lot fo things you can specify.
But I cant find good info on how it works to help you find want you look for faster.
Windows 11 - TVpaint 11.7.1(dec 5 2022) pro - Wacom cintique 24 Pro
Re: brush - info
hellofilms wrote:I am trying to digg into the world of the settings of a brush. There are really a lot fo things you can specify.
TVPaint 9 demo, but still good info on brush settings:
hellofilms
Re: brush - info
Thanks,
I did not see the configuration video among the tutorials but now I realize it´s because I had choosen version 10.
There is much testing before you learn the settings but this is a good start.
In the tool-settings theres a Bin-feature.
I understand it works like when you click there current brush to a kind of tool-archive.
Is these Bin just temporary or are they saved?
/ Mattias
Re: brush - info
hellofilms wrote:...
they are saved.
... at least when you quit tvpa properly,
in case of crash, they will be lost, so to secure your custom-brushes saving,
imo it's preferable to store them in a custom panel (... grab current tool ),
... then save the custom panel by exporting it (.tvpx file) somewhere on a secure HD.
hellofilms
Re: brush - info
Yes I have used the export bruhes when working with others or wanted to use a set of brushes in a project.
It would really be nice if there was a kind of manual listing what all the settings mean.
And a few basics on creating spec brushes.
But I guess I have to testing and have a look at how the other brushes are created.
Re: brush - info
These are two utility buttons I use to analyze the parameters of tools and brushes. Comes in handy sometimes. Also I'm uploading a PDF tutorial on setting up a custom brush panel.
Tools & Brush Forensics.jpg (5.19 KiB) Viewed 12751 times
Custom Brushes in TVPaint the Easy Way.pdf
(241.7 KiB) Downloaded 725 times
Tool & Brush Forensics.tvpx
(147.5 KiB) Downloaded 708 times
hellofilms
Re: brush - info
Thanks! Great!
I am starting a project where I plan to explore the brushes.
I might come back with questions.
