Hi, i dont know much about script. i can create some toolbars and action, but nothing to fancy.
i want to create a button that erase only the blue in 50% in the entire image (because the blue by default its too hard).
anyone can give me some help?
thanks!
magic ereaser blue 50% Topic is solved
Re: magic ereaser blue 50%
This code turns down the aalpha channel in the blue channel of the current image with 50%
is this what you was looking for?
You can read about the command here
http://wiki.tvpaint.fr/index.php?title=Tv_PixelMatrix
I have also put it in a custom panel.
Hope it helps.
-Mads
tv_pixelmatrix 1 0 0 0 0 0 1 0 0 0 0 0 1 0 0 0 0 -0.5 1 0
Hope it helps.
-Mads
- MEB50.tvpx
- (4.5 KiB) Downloaded 205 times
JUST PERFECT! THANKS MADS!!!!
(y suppose that if i change the "0 0 -1.5 1 0" for "0 -1.5 0 1 0" work with the red or green, right?)
Glad I can help.juansolimar wrote:JUST PERFECT! THANKS MADS!!!!
Yes this should turn down the red channel
tv_pixelmatrix 1 0 0 0 0 0 1 0 0 0 0 0 1 0 0 -0.5 0 0 1 0
tv_pixelmatrix 1 0 0 0 0 0 1 0 0 0 0 0 1 0 0 0 -0.5 0 1 0
I didn't know geroge can control alpha value of Blue channel.
By the way, is it possible to fill only transparent areas(alpha value 0) with specific colors?
HI! i was wondering. what if i want to erease by 50% only the black lines?
thnks
thnks
Check out the half-erase panel I just posted in the Contents Sharing section:
http://forum.tvpaint.com/viewtopic.php?f=11&t=10684
Thanks!
David
Thanks!
David
