Addin JitterControl to WetProfile+Pressure and ProfileMarker
TheQuestionMark
Post by TheQuestionMark »
Is there a way to Jitter the Wet Profile? Also is there a way to Jitter with Pressure I want to apply pressure but I want to add a small and contolled jitter not to much, on opacity. I tried tweaking the Profile Editor to make it Jittery and Random as possible so I can apply pressure with jitter-ish, but it doesn't seem random enough. Is there a way to jitter-controlled for opacity and maybe size too?
Is there chance to add a feature to have Profile 'Marker' Editor.
On Profile Editor with marker, is there a way to when you apply pressure the 'Profile Editor' highlights the area of the line of where to pressure apply so you can and tweak that area on the Profile Editor. I'm not sure how to tweak for the Wet Profile though.
Re: Addin JitterControl to WetProfile+Pressure and ProfileMa
TheQuestionMark wrote:Is there a way to Jitter the Wet Profile? Also is there a way to Jitter with Pressure I want to apply pressure but I want to add a small and contolled jitter not to much, on opacity. I tried tweaking the Profile Editor to make it Jittery and Random as possible so I can apply pressure with jitter-ish, but it doesn't seem random enough. Is there a way to jitter-controlled for opacity and maybe size too?
the only way I know for the time being, is to make an animation with the opacity (and/or size) gently varying along the animation
with a (low to high level) randomizing progress, easy to do with the FXstack and a "shark-toothed" profile,
then cut it as AnimBrush and set the Anim mode to Pressure, or Tilt, or Invert/Speed, (... or Altitude, Azimuth if your tablet/stylus use these data).
TheQuestionMark
Animation with opacity? How do I do it for Alpha Max? Does Animation-Brush Opacity work with Alpha Max Setting? I kind of like the thick edges hard edges and then and still hard opacity on the inside. Kind of like WaterColor Pencil. Do you know a setting to make it watercolor pencil-ish? Not watercolor, Watercolor Pencil style. Hard Strokes at first, but as you press harder the opacity slightly lighten and 'jitters a bit' and size gets bigger with control?
