george command to Get / Set the Play-FlipBook length ?
I would like to read/set the current Play FlipBook duration with a george command,
or is it already existing such a command ?
if not, why not to add the ability to set the FrameRate as well ?
something like :
TV_SetFlipBook [length] [FrameRate]
where "length" is the duration (in frames, or seconds),
and "FrameRate" the i/s nb for the preview playback speed.
8)
Re: george command to Get / Set the Play-FlipBook length ?
Also, when flipbook is played, it seems to loop forward, then loop in reverse, or loop in reverse then loop forward depending on where the current frame is. Why? I wonder if another parameter might be included to have flipbook optionally play forward only?
