move object with keyboard shortcut
Joost
Post by Joost »
For me it would be nice to have the possibility to make a keyboard shortcut for moving an object/image/layer 1 pixel to the left/right/up/down.
For example: Like in after effects, you can move your layer one pixel in the direction you want, using the 'arrow' keyboard shortcuts. And while holding shift, you can move it 10 pixels.
TVP Pro 11.7.1
Re: move object with keyboard shortcut
Joost wrote: For me it would be nice to have the possibility to make a keyboard shortcut for moving an object/image/layer 1 pixel to the left/right/up/down.
there's a little custompanel in the content sharing section which is basically doing that,
once the 4 buttons assignated (keys 2, 4, 6, 8 of the numeric pad f.i.),
you can pan the layer content 1 pixel per pixel, in the 4 directions.
of course, you can easily add a "10 pixels" version,
just copy/paste these 4 buttons, and edit the 4 script commands.
Joost
Post by Joost »
Thanks! I will check it out
TVP Pro 11.7.1
