I would like to import differently named images at once (it is not an image sequence). Is this somehow possible?
When I go to File->import I can only import one image at a time.
importing different images at once (SOLVED)
Re: importing different images at once
You can select a bunch of images and drop them in TVPaint. But the import footage panel will open for each image.
Ok, I will do that, thank you!
