I am working with film which will be in a more painted style.
In the developement I pick different color that I think works fine and add them to the color palette bin.
The last color always are added last in the row of colors, and after a while it becomes a little of a mess.
Is there a way inside TVpaint to organise the colorsswatches in a better way so they are poistioned nearby close colors.
Or are there any other way to import a saved palette and organise it and then import it again.
/ Mattias
Palette - organise it
- hellofilms
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
- neonnoodle
Re: Palette - organise it
It is often better to grab your colors into buttons in a custom panel -- that way you can move them around, name them, etc.
- hellofilms
Seems like a good solution.
I try to drag them into new positions but it doesn´t seems to work.
/ Mattias
/ Mattias
- neonnoodle
You can't drag/drop (for the timebeing), you have to use copy & paste.
