Custom Brush HELP
Custom Brush HELP
Hi there,
I need some serious help about my custom brush.
It is really simple one and i get what i want except that brush have some "jitters", "zigzags", i dont know how to call it.
The line is not strait when a draw it in some angle or when i do curve Every parametar that i change line still isnt smooth like it should be.
Have same problem in the other programs like SketchBook, but somehow i menage to smooth it
What parametars should i change to make look "normal" without that "zogzags"?
Windows 8 64
Tvpaint 10 Pro 32
Wacom Cintiq 21UX
Windows 8 64
Tvpaint 10 Pro 32
Wacom Cintiq 21UX
- Picture of "ziggy" lines
- BrushIssue.png (71.55 KiB) Viewed 22491 times
Re: Custom Brush HELP
Can you post your custom panel (as a tvpx) with your brush inside ?
I can, ty
- OutlineTST.tvpx
- TST Brush with "zigzags"
- (197 KiB) Downloaded 828 times
Well, if you want my opinion :
- jitter should be avoided if you do not want to have "zigzag"
- to draw normal lines, you should maybe use the simple pen brush
- if your zoom ration is not 100% (or a full value, like 50%), a kind of blur can be visible (but it does not exist for real, it's just because of the zoom ratio).
Jitter is set to "none".
I tryed with simple Pen Brush (its the closest to what i want) but still have the same problem
Controls that PenBrush have: Size: Pressure
Power: None
Opacity: cant have any control, default is 100%
Drying: checked
Gradient: off
AAliasing: checked
I really dont know where is the problem
Power: None
Drying: checked
Gradient: off
AAliasing: checked
Sorry, I meant "Shift" (I was using the French version).8ball wrote:Jitter is set to "none".
What if you use the line smoothing ?
....and yes, i also considered zoom factor;
i work on various drawings on a full HD format, and if i zoom in/ out, or work in real size, the line is the same (zigzaggy, jittered, whatever)
...Like it have tendency to go straight on curves or angels. Maybe because pixels on monitor are putted in cross formation, i dont know.
On the other hand, how can i draw "normal" lines in Sketchbook or Photoshop, then its not problem with pixels.
bdw ty on ur earlier answer
on my custom brush i put line smoothing to best, without it it looks like hell
No, no, I meant this :
If you increase the line smoothing value, you should have a better quality.
The last version is 10.5.7 : if you are not using this version, you should update.
What's your version exactly ? 10.x.xTvpaint 10 Pro 32
crap! i have 10.0.16 V
....and i cant find Shape options
Time to update, don't you think ?
Unless you are using a cracked version... If so, you will banned from the forum because there is no reason I lose time with someone who has not even purchased his/her license.
Really TY 4 ur time and effort to help me.
...and yes i have cracked version cause i dont have money to buy a legal one.
Feel free to ban me.
Banned for using a cracked version.
Legal proceedings in progress.
