Panning Tool in keyboard shortcuts?
Sewie
Post by Sewie »
Panning Tool.jpg (30.85 KiB) Viewed 15598 times
For some reason I cant find the 'Panning Tool' in the keyboard shortcuts? Has it been removed or renamed because I vaguely remember having set it in the past?
Re: Panning Tool in keyboard shortcuts?
tools: Position Reset Scale ?
Sewie
Post by Sewie »
Just tried it but that's not it...
Very strange because 'Reset Panning' is available in the Keyboard Shotcut window.
What are you looking for it to do? Is it that you want a keyboard shortcut to select the panning tool and once you press that key you can move your drawing around? If that is it, it works for me. :?
Sewie
Post by Sewie »
Paul Fierlinger wrote:...Is it that you want a keyboard shortcut to select the panning tool and once you press that key you can move your drawing around?
Exactly that.
But when I set 'Position Reset Scale' it resets the scale for the Transform Tool, which makes sense.
I want to set the Panning Tool because (I recently found out) it can move drawings without degrading them.
I spotted my mistake. When I tried the key command I was still under the influence of my custom button. Here it is:
SHAPE PAN.tvpx
(54.5 KiB) Downloaded 635 times
Sewie
Post by Sewie »
Thanks Paul! I'll set the button.
But the omission of this option in the Keyboard Shortcut is a mistake, I believe, so: Bug Report!
It's under SHAPE TRANSFOM >> PAN
Sewie
Post by Sewie »
Ah, for crying out loud! Thats it. Got lost in translation again, I suppose.
Thanks, Schwarzgrau.
Edit; But I think it would be good if it got renamed as 'Panning Tool' in the Keyboard Shortcut window, just for clarity sake.
So forget the Bug Report and now it's a; Feature Request.
Yea, it would make sense if the tool-tips match with the shortcut functions.
Ah, so that's what happened. I saw that Shape Transform Pan command from the beginning and thought the Key Command Panel was referring to my plugin, so I copied the button, shortened the name, and sent it here. This has also fooled me before. Often you can't tell if the panel is reading your custom panel or referring to the real, built in thing.
Localization error tracked. Thank you !
