TVPaint 11 Smoothing Option vs TVPaint 10.5.7 with Lazy Nezu
TheQuestionMark
Post by TheQuestionMark »
Line Smoothing feels wonky from TVP 11
Just trying TVPaint 11. .
It seems like with Lazy Nezumi the line stroke is behaving more oddly. Or isn't behaving likely it should. Have you try Lazy Nezumi Pro with TVPaint 10.5.7. Seems like TVPaint 10.5.7 with Lazy Nezumi Pro behave way more differently than TVPaint 11. And TVPaint 10.5.7 with Lazy Nezumi Pro is more fluid and more accurate. Not only that there a bug on TVPaint 10.5.7 that glitches out Lazy Nezumi Pro and stops working.
I think TVPaint 11 line smoothing needs to be more tweak . Or anyway to make TVPaint 11 with Lazy Nezumi Pro, act more like TVPaint 10.5.7 with Lazy Nezumi Pro.
There's still no 'pen catch up option' for TVPaint 11. Or if you to use TVPaint 11 with Lazy Nezumi it feels buggy and does not behave like TVpaint 10.5.7 with Lazy Nezumi Pro.
TVpaint 11 Trial.
The draw smoothing should be more like TVPaint 10.5.7 with Lazy Nezumi. Not like TVPaint 11 with Lazy Nezumi or without.
TheQuestionMark
Re: TVPaint 11 Smoothing Option vs TVPaint 10.5.7 with Lazy
No Response for this post? It's so Important. Fixing the Bug in TVPaint 10.5.7 and TVPaint 11.
TheQuestionMark
Re: TVPaint 11 Smoothing Option N TVPaint 10.5.7with Lazy Ne
I discover a new bug TVPaint 11. Please Fix.
When you turn on Lazy Nezumi Pro. And then Lazy Nezumi off and then on. Lazy Nezumi Pro stops working the "Pen Catch Up of Lazy Nezumi". You have to go to Preference turn the tablet in "Ink" Mode and then switch it back to Wintab and Subpixel for it to work. Can you please fix it?
I'm sorry, but there is no way for us to fix a software we didn't develop ourselve and which is not either a plug-in of TVPaint.
From what I understood, it intercepts the informations provided by the Wacom drivers and changes them ... then TVPaint gets more or less the result, maybe with some potential errors or misunderstanding regarding the received/perceived messages.
I might be wrong, but I'm afraid there is absolutely nothing we can do.
TheQuestionMark
Fabrice wrote:I'm sorry, but there is no way for us to fix a software we didn't develop ourselve and which is not either a plug-in of TVPaint.
I just got an e-mail from Guillaume Stordeur the person from Lazy Nezumi Pro, and they said it's on TVPaint Side. And that person said:
CatchUp doesn't work with TVPaint, because of how they have coded their input.
It will never work, so just disable it when you use Moving Average mode, or use Pulled String mode instead.
The bug glitch seems to be related Edit-> Preference, Tablet Wintab and Sub-Pixel ON. If switch Sub-Pixel off it slightly 'works' but 'Pen Catch Up" mode from Lazy Nezumi Pro doesn't work. Please fix for TVPaint 10.5.7 and TVPaint 11. I really need the 'Pen Catch Up' from Lazy Nezumi Pro.
Suggestion Maybe?
In Edit-Preference-Tablet.
Tablet-------->Wintab
-----------------Sub-Pixel
-----------------Plug-in?
-----------------Sub-Pixel // /////////// "Mouse Over Description"
-----------------Plug-in? ////////////// Mouse Over Description->"External Drivers or Plugin when Drawing" ?Overides Sub-Pixel and Psuedo Wintab
For please both TVPaint 10.5.7.
And also TVPaint 11.
