Drying Bug ?
Jerome Boulbes
Drying Bug ?
Post by Jerome Boulbes »
Hello everyone
I am having hard time trying to understand the drying mode. Whatever I draw I get the same result with or without it. (tried with the oil, wet and custom brushes)
(TVPaint 10.5, )
Does it require some option to be activated ? does it works only with some specific mode ? And what is it supposed to do exactly ? The manual is a bit light on the subject I think.
Re: Drying ?
Use some brush with 40% opacity and compare drying to non-drying. Do several strokes.
Jerome Boulbes
Re: Drying ?
Thanks !
but still I can't see any notable difference :?
Do I have a bug ? Or more probably, am I completly misunderstanding something ?
Jerome
Re: Drying ?
It's not for the opacity settings, but for the power settings.
I set the power of the brush to constant 70% and drew the left crossed circle with drying, the right is without drying.
Jerome Boulbes
Re: Drying ?
Thanks everyone, but it still doesn't work for me.
Is this a "pro feature" ? Is there an option in the preferences that I have deactivated by mistake ? Or hardware connected ?
I do not believe this is a bug, because I think I remember it did work at some point as per the manual, when I first tested the software.
TVPaint team, any input ?
I have tried a lot more options/configurations than in the image below...
Jerome Boulbes
Re: Drying ?
Got it !
It's connected to Line smoothing.
When Line smoothing is ON, Real Time should be ON too.
With RT OFF, it doesn't work.
habashtvpaint
Re: Drying ?
Post by habashtvpaint »
Yes, I confirmed Jerome's test. just tried it
Thanks for sharing this.
Animator for Life
Animark
Re: Drying ?
Post by Animark »
It remembers me on another bug also is connected to "Realtime Line Smoothing":
The jumping frames of an Anim-Brush.
http://forum.tvpaint.com/viewtopic.php?f=10&t=4464" onclick="window.open(this.href);return false;
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Re: Drying Bug ?
Bug added in the todo-list
