I was wondering if there is a way to apply the FX frames on 2s (on every other frame, instead of on every frame). I just want all my animation to be the same "fluidity" so a movement on 1s would stand out. Right now I am manually deleting every other frame. Or maybe there is a way to select multiple instances and delete a frame in each instance?
cheers
motion keyframer render on 2s [solved]
momo
Re: motion keyframer render on 2s
Hi Momo,
I know of 2 ways to reach your goal:
You can put as much of empty frames (timed on 2's) on the layer where your movement should rendered to. Than set the "Apply on" setting at the bottom of the FX Stack to "apply on heads".
The other way is to make your movement on half of the frames you will need in the end. After the rendering you can simply double the frames. The result should be the same as in the way mentioned above.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
