Example:
You have a Previously Saved Project open displaying a specific image on screen. You press the SavePlace button and information about the Current Project Name, Current Clip, Current Layer, Current Frame is saved to the Config.ini file.
NOTE: The SavePlace button only works with Projects that have already been named and saved at least once and you will be warned if it was not yet saved...
At any point in the future, even after exiting and reopening TVPaint, you can immediately press the ReLoadPlace button to access the saved info from the Config.ini file, which will AUTOMATICALLY RELOAD the saved Project, saved Clip, saved Layer and saved Frame. If the Project is already open but at some other location, it will jump immediately to the saved Clip, saved Layer and saved Frame location.
What Gets Saved?
The Project filename (including the complete path to the file) the number of the active Clip, the number of the active Layer and the number of the active Frame is stored as a single string parsed by spaces.
If the Project is significantly modified (Clip, Layer and/or frames are INSERTED) the the ReLoad Button might not return you to the same location that was saved.
How are the Buttons Used?
Typically, the SavePlace and ReLoadPlace buttons would be used to save your current working location, then return there when you begin working the next day. IMPORTANT: remember that the Project should already have been saved at least once, to establish the path where you want the SavePlace button to save in the future.
Future?
Ideally, as suggested by Mads, the File SAVE and LOAD commands should store and retrieve the current Clip, Layer and Frame in effect when ANY Project is saved, then offer to restore to the sameClip, Layer, Frame location when the Project is reloaded.
(Thanks Paul for testing this button set!
