settings keep changing
HOW DO I FIX This , every time i set some parameters of a tool and switch to some other tool , the settings of the first tool goes back to the defaults.How to i fix this/?
Re: settings keep changing
What operating system do you use and which version of TVP do you have (the entire number, including the last two digits which indicate the build)? Without this minimum of information it's hard for anyone to be able to answer most questions reliably.
Tvp10.0.16 running on window 7 ultimate.Paul Fierlinger wrote:What operating system do you use and which version of TVP do you have (the entire number, including the last two digits which indicate the build)? Without this minimum of information it's hard for anyone to be able to answer most questions reliably.
It's time to update to TVPaint 10.5.7. It's free for registered users and you will enjoy the last bugfix.
