Help key to move the program TVP9 from one PC to another!!!!
Locked
sashaneo1
Post by sashaneo1 »
Good day to you!
There is need to transfer your software TVP Animation 9 from one computer to another. Please tell me how this can be done while maintaining the license to another PC by removing it from the previous one?
Thank you very much looking forward to your response.
Léo
Re: Help key to move the program TVP9 from one PC to another
Post by Léo »
Hello sashaneo1,
You have just to install TVPaint on your new computer and plug your dongle on it. You don't need to uninstall TVPaint from the previous one. :)
Léo Fernandez
Wacom driver version 6.4.2-3
sashaneo1
Post by sashaneo1 »
Tell me where I can see the key if the drive is lost and the program is installed with the purchased key?
I'm afraid I didn't understand what you just said :(
I think sasha thinks the key was created by the computer which was used when purchasing the dongle and doesn't realize that both the lock and unlock keys are tied to the dongle. Sasha, wherever the dongle goes, there you have your software, so if you stick the dongle into a computer that has never seen TVPaint, you can download the demo version and your dongle will turn it into a legitimate, functioning program, unlocked by typing your key into TVP's download panel.
ematecki
Post by ematecki »
Not exactly.
You have to download the full version, using your codes.
The demo will never turn into a full version.
Sorry for the misinformation but I believe this is how it used to work at one point.
ematecki
Post by ematecki »
That was loooog ago, Aura 2 was the last one working this way, I believe.
Yeah, my short term memory is shot so that's about right. :roll:
sashaneo1
Post by sashaneo1 »
Let me explain the problem again). The fact that I did not install this program on your computer and you need to reinstall the software on another computer and look where key program installed earlier, I do not know. The key is thrown when kopupke lost. Was only in the installed program, because it is necessary to somehow see to register the program on another computer instead of the existing. :?
sashaneo1 wrote:Let me explain the problem again). The fact that I did not install this program on your computer and you need to reinstall the software on another computer and look where key program installed earlier, I do not know. The key is thrown when kopupke lost. Was only in the installed program, because it is necessary to somehow see to register the program on another computer instead of the existing. :?
I don't understand what you mean by "and look where key program installed earlier" and "The key is thrown when kopupke lost" .
But what you want to do is really very simple:
1.) reinstall TVPaint on your new computer from the software install CD that you received when you purchased TVPaint. (make sure you also install the Sentinel security drivers on the new computer.)
2.) Now plug-in your TVPaint dongle.
3.) Start TVPaint and enter your lock/unlock codes . (the lock and unlock codes should have been with your original software install CD and hopefully you wrote them down someplace . If not you can contact TVPaint Support to recover your lock/unlock codes from your name in the database of registered TVPaint users)
4.) Go to Check for Updates under the Help menu to update it to the last available version of TVP 9 , which was 9.5.21 . (because the version you have on the software install CD is probably not TVP 9.5.21 , but an earlier version of TVP 9 ).
sashaneo1
Post by sashaneo1 »
Sorry.
"The key that was given when buying lost."
sashaneo1 wrote:Sorry.
So you use TVPaint Animation 9 without dongle ? :o
sashaneo1
Post by sashaneo1 »
Yes, the program is used TVPaint Animation 9. The user who bought this product, says that the key has been activated and the program. Currently it is used as activated upon purchase.
Since I am with this program did not work, and the task set to move it along with the license to another computer, I need to know the key to activate the program, which is now working with the user. :|
sashaneo1 wrote:Yes, the program is used TVPaint Animation 9. The user who bought this product, says that the key has been activated and the program. Currently it is used as activated upon purchase.
if you have no dongle, it just means you are a pirate.
We will not help nor give any support to a thief.
Only real TVPaint registered users are welcome to ask us how to move their software from a computer to a new one.
Topic locked.
Locked
