imported images
momo
imported images
Post by momo »
I was wondering if imported images become part of the .tvpp file or do they function through dependency like for sounds?
momo
Re: imported images
momo wrote:... I was wondering if imported images become part of the .tvpp file or do they function through dependency like for sounds?
both are possible,
depending on your "Preload" option, if it have been checked ON/OFF when importing the sequence.
momo
Re: imported images
Post by momo »
Thanks ZigOtto,
I didn't know about that checkbox.
I assume that under project->dependencies->save dependencies into the project lets you save all dependencies to the .tvpp files?
momo
Re: imported images
Manual_dependencies
it is possible to preload the files later via the main menu Project > Dependencies > Load all. This menu also displays the path and name of files on which your project depends.
momo
Re: imported images
Post by momo »
Right but that doesnt explain what does the "save dependencies" button does exactly.
momo
Re: imported images
Dependencies are external sources.
When you save dependencies, you don't depend anymore on external sources, since they are loaded in your project.
That makes your files bigger, but at least, you won't have any bad surprise when opening them (aka "damn, i forgot to copy my my sound and images files, now I cannot work without then")
Re: imported images
Maybe a name like "integrate dependencies" could be a bit more fitting
Re: imported images
or "embed dependencies ",
like you can embed custom panels in your current project.
Re: imported images
ZigOtto wrote:or "embed dependencies ",
+1 exactly.
momo
Re: imported images
Post by momo »
Elodie wrote:When you save dependencies, you don't depend anymore on external sources, since they are loaded in your project.
Thanks for the accurate answer, Elodie.
+1!
momo
habashtvpaint
Re: imported images
Post by habashtvpaint »
"collect dependencies" or "consolidate dependencies" also could be a good command name.
Animator for Life
