Render Auto Paint
Render Auto Paint
I'm want to use Auto Paint FX for automatic drawing.
But the line of the final render is different then the line I drew.
The applied auto paint was done with the same brush.
I tried several things:
recording with "Use pressure" off and turning it on when applying, or vice versa etc...
See attachement
So far I haven't found a solution.
I also tried the "drawing recorder", but the underlying layer/drawing (which I use as reference) is always rendered.
See attachement
- Autopaint.jpg (291.35 KiB) Viewed 16597 times
MacOSX 10.9.2 - 64bit - TVPAINT 10.5.7 PRO
Re: Render Auto Paint
Hello timson,
I see on your signature that you have TVPaint 10.0, which is quite an old version. You should first update to TVPaint 10's latest version, 10.5.7 (it's a free update ) and see if you still have this issue.
Hello Thierry,
I have to update my signature, I'm using the latest version.
Would upgrading to version 11 solve the problem?
I'm in production and I need a solution.
Maybe another software? Photoshop records drawings but can't export it... screen grabbing is not a solution because i need 4k, 5k resolutions...
Important is to have good graphic brushes like in photoshop
I just happened to be working with the Drawing Recorder in TVP-11.0.1 and it works like a charm. Just now I I went there again to emulate your drawing and it comes out looking just the way I drew it.
Since the auto recorded image ends up in a new clip, I could flip between my original drawing and the recorded one and there was absolutely no difference between the two-- it's actually pretty clever the way the gadget is designed.
yes, I was about to suggest to use the drawing recorder instead.
Thanks a lot for the support!
I'm using the 10.5.7 version maybe thats the problem:
the new clip from the record in the Drawing Recorder has the reference image included - which I use in transparency
Is TVP-11 the solution?
In the 10.5.7 , you should be able to select in the drawing recorder if you want to record the display or the current layer only.
Hi Fabrice,
This seems to be the solution.
Thanks!!!
Thanks!!!
