Problem installing Sentinel Drivers on Linux Mint
Posted: 13 May 2015, 08:16
by namyrb
Hi,
Running linux mint 17.1 Cinnamon and I'm not able to successfully install the Sentinel drivers (from the 10.5.7 package). I've tested it on other distributions including Ubuntu Gnome and Centos and everything worked fine. Mint is the only distro that isn't working for me. I get this error when I try to install:
This script will install Sentinel USB Daemon 7.5.1:
Selecting previously unselected package sntl-sud.
(Reading database ... 202165 files and directories currently installed.)
Preparing to unpack sntl-sud_7.5.1-0_i386.deb ...
Unpacking sntl-sud (7.5.1-0) over (7.5.1-0) ...
USB Daemon uninstalled successfully.
Setting up sntl-sud (7.5.1-0) ...
-e
Error: Problem in starting Sentinel USB Daemon, Please run load_daemon.sh manually.
Did some digging and I tried running load_daemon.sh manually and it gives me this error:
./load_daemon.sh: 59: .: Can't open /etc/init.d/functions
I checked /etc/init.d and functions does not exist in that directory...
Any advice?
Thanks
Re: Problem installing Sentinel Drivers on Linux Mint
Posted: 13 May 2015, 09:17
by Eric Scholl
Hi namyrb,
It's a known problem which should be solved in the next updates of TVPaint.
We know that if you tried to install the other package, you could have some files to remove manually.
So please follow exactly all the steps of this process:
1) Remove the /opt/safenet_sentinel file if it exist, using the following command :
sudo rm /opt/safenet_sentinel
2) In the OLD safenet sentinel installer, go in "sentinel_protection_installer/Debian_support/driver" and execute the "sud_uninstall.sh" script using the following commands :
cd  sentinel_protection_installer/Debian_support/driver
sudo ./sud_uninstall.sh
3) Download the NEW installer using the following link and extract it anywhere you want it to be.
sentinel_protection_installer_forMint.zip
(4.43 MiB) Downloaded 1791 times
4) In the NEW safenet sentinel installer, go in "sentinel_protection_installer/Debian_support/driver" and execute the "sud_install.sh" script using the following commands :
sudo ./sud_install.sh
After that, everything should be installed as it should.
Posted: 13 May 2015, 10:25
by namyrb
It works! Thank you!
Posted: 06 Mar 2016, 12:17
by Lars K
Hey, sorry for hijacking an old thread, but I'm still having this very problem.
I'm using a 64-bit Arch Linux, barely a week old, and a freshly downloaded TVP11 Pro. TVP was installed without much problem using debtap, but none of the Sentinel install scripts work, giving me the same error message:
This was also true for when I tried to install it on my laptop a couple months ago.
Any help would be appreciated. :)
Posted: 11 Mar 2016, 21:25
by Lars K
Alright, so I got it somewhat working, but I have to run both the usbdaemon and tvpaint as a super user for the dongle to work, and it is very unstable, probably because I used a poorly converted install script. It occasionally crashes on normal operations such as cutting, and it plays any animation fine, until I stop it, at which point it freezes. That's about as much as I can do for now, though, so all I can do is hope you add support for Arch some time in the future. :)
EDIT:
Fabrice wrote:protection system will evolve, but in a few months.
That's cool, looking forward to that. I got Windows working again just five seconds ago, so I'm not completely lost in the meanwhile. :D
Posted: 13 Mar 2016, 15:29
by Fabrice
Posted: 23 Oct 2016, 20:44
by namyrb
Hi,
Are there updated sentinel drivers for ubuntu 16.04?
Thanks
Posted: 24 Oct 2016, 15:54
by neonnoodle
I have had no problem with the existing Sentinel driver on Ubuntu 16.04. Sometimes I have to run the daemon manually before I start up TVPaint, but it works.
Posted: 10 Nov 2016, 08:54
by namyrb
I was definitely having a problem, but I think it's because I'm using KDE Neon.
load_daemon.sh was trying to open '/etc/init.d/functions', but inside the script it's supposed to run '/lib/lsb/init-functions' for Ubuntu/Debian
For whatever reason, it doesn't seem to believe it's debian so it decides to run '/etc/init.d/functions'
So I went to these lines in 'load_daemon.sh':
case $OS in
SUSE)
	. /etc/rc.status
Debian)
	. /lib/lsb/init-functions
    . /etc/init.d/functions
esac
and changed '/etc/init.d/functions' to '/lib/lsb/init-functions'
Seems to work now.
Posted: 22 Jun 2019, 11:57
by deruji
Lars K wrote: 06 Mar 2016, 12:17 Hey, sorry for hijacking an old thread, but I'm still having this very problem.
Sorry for bumping this old thread. I'm in a similar situation using 64-bit Manjaro based on Arch Linux. TVpaint itself runs without problems, I only have to manually start the sentinel driver.
Has anyone found a workaround or modified install script for the sentinel driver?
Posted: 24 Jun 2019, 00:58
by Lars K
My solution was to install start-stop-daemon from the AUR, and in load_daemon.sh commenting out the bit where it looks for ". /etc/init.d/functions", and default all the rest of the cases to the debian option. tvpaint should work like a charm after that. Bit of a lazy hack, I'm sure there are better ways, but hey.
deruji wrote: 22 Jun 2019, 11:57
