In the Export to.. dialog there is a Mode selector for "Palette", "RGB","RGBA" and "Alpha only".
Is there any way to set this to RGBA for export of PNG sequence from george script ?
Best regards
HC Jehg
...SaveSequence PNG as 32 bit RGBA
Re: ...SaveSequence PNG as 32 bit RGBA
You'd want to use tv_AlphaSaveMode. You can see it on the docs here.
It's not clear from the docs but nopremultiply does what you need.
tv_AlphaSaveMode "NoPreMultiply"
