Can't erase
Can't erase
This problem is probably very easily solved, but I'm a stumped newbie so I figured this was the fastest way to get some help. I cannot erase on one layer of a new clip I just started. I'm using the sketch panel, all layers are drawn with red pencil, none are locked, and three can be erased successfully. One in the middle, however, is unchanged, no matter how I make new frames or which eraser I try to use. What button did I press to mess this up?
- schwarzgrau
Re: Can't erase
I guess you locked not the layer but the transparency. Which TVPaint version do you use?
Re: Can't erase
I'm using TVPaint 10 standard edition. I'll admit to that being a strong possibility, but I'm afraid I'm not entirely sure how to tell. There are options next to each layer (view, lock, lighttable, truth be told I never use the other two) but none are highlighted. Its not locked, the visual is on, its set up exactly like the other ones as far as I can tell. Should I check something more specific, am I on the wrong track?
- schwarzgrau
Re: Can't erase
could you post a screenshot of the whole screen? I'm not sure if it will help, but maybe I can spot something.
Re: Can't erase
I don't know if this illuminates the situation at all, but let me know if there's more information I can send that might be more helpful. "Arms" is the layer that is stuck.
- Screen Shot 2015-05-28 at 9.49.38 AM.png (274.76 KiB) Viewed 25313 times
Re: Can't erase
First of all, you should update to the latest version of TVPaint 10 : 10.5.7, which is a free update
Re: Can't erase
Yes, the first step to solving the issue would be to update to the lastest version 10.5.7 . How to do it ? -- simply go to the Help Menu > Check for Updates . If you are a registered user then you'll be taken to a page where you can enter your Lock/Unlock codes and download the free update to 10.5.7 .Thierry wrote:First of all, you should update to the latest version of TVPaint 10 : 10.5.7, which is a free update
Re: Can't erase
Oops. I'll email the official TVPaint contact. But since I have you all here, any one know what I did wrong?
Re: Can't erase
Please send me your lock code via private message
Re: Can't erase
I have my idea...dguest wrote:any one know what I did wrong?
Re: Can't erase
ematecki wrote:I have my idea...dguest wrote:any one know what I did wrong?
sharing is caring.
Re: Can't erase
I know this post is old but did you ever find a solution? I am having the same problem.
- schwarzgrau
Re: Can't erase
It seems this problem is fixed in 10.5.7
