Sketch Panel RGB - AntiAliasing OFF - Perfect for Japanim !
Hi everyone,
I'm back from Japan and since most people work without Anti-Aliasing, I re-made the Sketch Panel RGB for their use. All tools are now working without opacity and with an aliasing.
Sketch Panel RGB - A-Aliasing OFF.tvpx
(1.38 MiB) Downloaded 341 times
len shinoda
Re: Sketch Panel RGB - AntiAliasing OFF - Perfect for Japani
Post by len shinoda »
ありがとう!
右下の「Quick look」ボタンはどんな機能ですか?
↓ google translation ↓
Thanks a bunch!
What kind of features Quick look button in the bottom right?
len shinoda wrote:ありがとう!
Thanks a bunch!
In the Sketch panel RGB the 'Quick Look' eye button hides colored lines on the current layer and displays the black strokes only for a 1 second interval, so you can quickly check your progress .
Sketch Panel RGB Quick Look eye button.jpg (42.64 KiB) Viewed 2235 times
CartoonMonkey
Post by CartoonMonkey »
Elodie, do you know the reason why they work with antialiasing off? Curious.
they generate the aliasing during the compositing , mostly because Retas doesn't manage it well.
