How do you make multiple frames in one frame?
I want to do a repeating animation then stretch the frame out without drawing the action again and again(tedious) just like in flash, is it possible on Tvpaint?
Re: How do you make multiple frames in one frame?
"Like in flash", hum... most people here have never used flash or used a long long time ago.
Do you mean something like "repeat image" ?
-> http://www.tvpaint.com/doc/tvp11/index. ... eat-images" onclick="window.open(this.href);return false;
what's your tvpa version and your OS ?
if you mean "repeated (loop) animation" inside an animlayer, have a look to the "Faux-Fixe" feature in the manual,
- drag the last instance's tail to set the wanted length on the timeline,
then, go next to the last frame of your animated sequence, set the nb of frames (to be repeated),
and the repeat mode (loop, ping-pong, random).
