Make project panel go full screen in TVPaint 11
jcarter20
Post by jcarter20 »
Hello, I'm very new to TVPaint 11 and have tried to locate the answer to my question in the online docs, but I apologize in advance for posting here if I have overlooked it. My question is "How do you maximize the project panel on screen so that you are drawing at a 1:1 scale? In TVPaint 10, I believe you could hit the "0" key and the project panel would enlarge to full screen, over the timeline. Very convenient. Anyway, the same key command does not seem to work in version 11 and I can't seem to locate this command in any of the drop down menus. Am I missing something obvious?
furushil
Re: Make project panel go full screen in TVPaint 11
Post by furushil »
jcarter20 wrote: believe you could hit the "0" key and the project panel
The same shortcut should work in TVP 11. Try to look up "toggle layer panel" in the keyboard shortcuts (CTRL+K).
toggle layer panel.png (31.57 KiB) Viewed 10602 times
jcarter20
Post by jcarter20 »
Thanks Furushil; great suggestion and I will do this. I guess my biggest struggle right now with TVPaint is knowing the correct nomenclature to look things up like this in the docs :-)
All the best,
-John
