Learn TVPaint from Video tutorials
To talk about anything else
studiolincon
Post by studiolincon »
Are you looking to start learning TVPaint?
You can find tutorials on TVPaint at http://youtube.com/c/studiolinconza
More will be put up in the coming months :D
Re: Learn TVPaint from Video tutorials
Studio Lincon is not in our user base.
Moreover you are using the 10.0.16 version of TVPaint Animation, which is known as a cracked version.
If so, you lack the legitimacy of making tutorials and even less selling them.
Please clarify the situation, or you will get banned.
studiolincon
Sorry about that. You can delete the post. Was given a copy by a friend. Will look into it.
Thanks
If this a legit copy, you should update your software.
If you want to make tutorials, you might as well do them on an updated and legal version.
studiolincon
I agree. Will get it all sorted :).
Thanks for your comments
Also, may I suggest that if you're going to offer tutorials about how to animate , you should understand how to animate (better).
You've got one called "Bouncing Ball Final Render" .
https://www.youtube.com/watch?v=j6Xx6lSfObo" onclick="window.open(this.href);return false;
The "rendering" on the ball is ok (although the drop shadow makes no sense because it's not contacting the ground plane) , but nice surface rendering doesn't mean anything if the animation doesn't work . The arcs and spacing on the bouncing action of the ball are incorrect, especially near the end when the ball should be losing momentum and slowing down , it is way too "jumpy" and fast at that point . As it is rolling to the right the ball pops-off on the last frame , but should have continued to roll off screen (more slowly) as it is coming to a stop . The bouncing ball is an intro-level animation exercise. Master the spacing and timing of the bouncing ball before you offer to teach it to others.
Here's what I meant about the drop shadow and where it should contact the ground plane , based on the light source indicated by the rendering on the ball --
Drop Shadow is not on ground plane.jpg (72.69 KiB) Viewed 22304 times
Position of cast drop shadow copy.jpg (64.15 KiB) Viewed 22304 times
