[solved] Stylus pressure issue
aAntin
Post by aAntin »
Hi TVPaint community!
I have an issue with my stylus pressure in TVPaint:
I'm using TVPaint 11.0.0 pro on Windows 8 and I've just installed my new Wacom tablet Intuos Pro. The tablet is working fine on Windows as well as in Photoshop, but it seems that TVPaint doesn't recognize its pressure feature. Of course, I've already double checked that I had the pressure option selected for my brush tool. I've also downloaded the last update of my tablet's driver on Wacom's website and installed it. Also restarted my PC but the pressure still doesn't respond in TVPaint...
Is there any option somewhere in TVPaint that I should turn on?
Would you have any idea to have it work properly?
Thank you, everyone!
Antoine
Re: Stylus pressure issue
Hmm, First, I would advise you to update to TVPaint 11.0.1.
Then, you should check my TVPaint preferences, in order to make sure if you're using WinTab or Ink options.
aAntin
Post by aAntin »
Hi Elodie,
Thank you for your fast reply! :)
I've installed TVPaint 11.0.1, like you suggested. Also checked at my tablette preferences and turned it to Wintab, it's working fine now! It was so simple, I feel stupid!!...
Thanks, Elodie!
Re: [solved] Stylus pressure issue
Don't feel stupid, it's our job to help you :D
aAntin
Post by aAntin »
