How to create a tool that selects a specific layer?
Farrow
Post by Farrow »
Hi, I was hoping there may be a way to create a tool that automatically selects a specific layer. For example if I have a black pen size 1.60 in a custom panel, is it possible that whenever I select that tool it could automatically take me to a specific layer, for example named "sketch"?
Something like Layer: Select "Sketch" Layer, if you know what I mean? :|
Re: How to create a tool that selects a specific layer?
Hello Farrow,
Yes it is possible :)
Here is a custom panel that does it. It contains a custom panel, with a black Pen Brush, with size 1.60, and it select a layer named "Sketch". If no layer named "Sketch" is found, then it display a warning.
Select-Sketch-Layer.tvpx
(56 KiB) Downloaded 970 times
And the George code :
loop=1
i=0
found=0
tv_layerCurrentID
current=RESULT
WHILE (loop)
	tv_LayerGetID i
	curLID = result
	IF (CMP(curLID,"none")==0)
		tv_layerSet curLID
        tv_LayerInfo
        PARSE result layerDisplay layerPosition layerOpacity layerName layerType layerStart layerEnd layerPrelighttable layerPostlighttable layerSelection
        IF (CMP(layerName,"sketch")==1)
        	found=1
        	loop=0
        END
	ELSE
		loop=0
	END
	i=i+1
END
IF (found==0)
	tv_layerSet current
	tv_warn "Layer sketch not found !"
END
thanks Thierry, cool script and button freely configurable,
for the layer's name, as for the tool's type and settings 8)
(just to mention it, a little mis-typing in your panel's name :
"select-sketcg", a "h" in place of the "g" would suit better)
ZigOtto wrote:(just to mention it, a little mis-typing in your panel's name : "select-sketcg", a "h" in place of the "g" would suit better)
Woops, fixed 8)
ultra-fast service ! 8)
a last note about this handy tool :
if you have several layers with the same "sketch" name,
the script will select always the upper one.
