[solved] tvpaint 11 standart and opensuse 13.2 64b
hello all
how are you ? i come to you because in some months i will pay my licence of tvpaint animation, on linux on opensuse 13.2 64
the fact is i personnaly downloaded the .rpm but not any installation from, even in console text mode the program gives me an error unnkwown
and i really do not know what to do
surrelly some libs to install but it's strange
thanx for replies
kindly regards
stéphane who loooooves tvpaint
thanx for replies
kindly regards
- Eric Scholl
Re: tvpaint 11 standart and opensuse 13.2 64b
Hi stefff285,
what version did you install ?
what kind of error do you get in your console ?
hello eric
as i'm french as you, i go make an english and french answer
hello eric. at first thanx to you. so then when i do "apper tvpaint.rpm" with the rpm renamed for simplicity, i go have a error but not any information about.
it is strange because most of times i have a error message when i try to install other software but not this time
bonjour eric. tout dabord grand merci pour votre réponse. alors quand je fais "apper tvpaint.rpm" (j'ai simplifié le nom du rpm) et bien cela me donne un erreur
inconnue . j'ai eu le meme problème sur d'autres paquets. bref je ne sais que faire. merci d'avance pour votre aide
stéphane
stéphane
- Eric Scholl
Hi,
Thanks for answering in both language, I think it's better to continue in English so future users which has the same problem will be able to find the solution.
Anyway, I cannot be of any help if the only answer I get is that there is an error whithout any further informations.
So here is some questions :
- Did you try to launch the installation by double-clicking on the installer instead of launching it from the terminal ?
- Can you post a screenshot of the error (even if there no information, a visual can be really helpfull sometimes) ?
- You said you had the same problem with other packets, what kind of packets ?
- Can you confirm you're installing a 64 bits version of TVPaint Animation 11 ?
hello eric
yes please accept my apologies i go write in english
so
- when i double click on rpm icon, the system search for but not give any installation processus
- i go make a screen shot immédiatly
- i had the same problem with some rpms, trillian for example
- yes it is the 64b version i downloaded on your website
thanx a lot for reply, i would be so nice to make a new short movie soon
kindly regards
so
kindly regards
- shoot.jpg (57.44 KiB) Viewed 29522 times
could you try to run in a terminal :
zypper install TVpaint.rpm
It should tell you that there is a dependence problem with libX11 and it should ask to choose between 3 solutions (abort, cancel or continue and ignore the dependence problem). Check with zypper (or another package manager) that a version of libX11 is installed (ie: zypper search libX11 in a terminal). Then choose the solution which ignores the dependencies issue. TVPaint will be installed and it should work without problem.
If you have a problem with these commands, please copy-paste the result in your response
hello back
so yes i tried zypper search libX11 but with simply as answer a list of possible installations
i give you it right now, as the shoot screen of zypper install tvpaint.rpm at first
thanx a lot
stéphane
thanx a lot
stéphane
- shoot3.jpg (49.53 KiB) Viewed 29493 times
- shoot2.jpg (73.97 KiB) Viewed 29493 times
Hi,
Yes, "zypper search" doesn't make install, it's just to search package
So the first screenshot shows what libX11-6 is installed (the left column "S" is for "Status", a "i" means "installed").
It's another problem when yun ran "zypper install" : it doesn't found the file. I think zypper doens't like "é" in the path. You should just do :
(I guess that the .rpm is there)
cd /home/steff/Téléchargements/tvpaint-rpm
hello jordane
yes i tried but without any result
it seems "zypper install TVpaint.rpm" in the good folder, go to search in the repositories
perhaps i have to ask to opensuse people too
regards
regards
If it's doesn't work with "zypper install tvpaint.rpm" (with the same error as before ?), then are your sure that tvpaint.rpm exist and is in that folder?
Please, paste the result of the commands
The result I got here:
ls -l /home/steff/Téléchargements/tvpaint-rpm/
hello jordane
oooooooooops please accept my apologies it works good ! in fine i forgot to completly respect the syntax
so TVPaint.rpm and not TVpaint.rpm
so then i have to wait for money to buy you the licence
thanx a lot
stéphane
thanx a lot
stéphane
