TVP11 - Break&Clear instance without auto-break???
tangofish
Post by tangofish »
Hi forum,
I recently moved from TVP 9.5 to 11 for a job and can't find a way to break and clear an instance WITHOUT using auto-break - which totally crashes my old workflow. -.-
In version 9.5 I set a simple shortcut to do so, which was very comfortable and worked great. But in TVP11 I can't even find a way to do it with clicking on something. Can anybody help?
Thanks a lot in advance!
furushil
Re: TVP11 - Break&Clear instance without auto-break???
Post by furushil »
please see this thread: viewtopic.php?f=10&t=9272" onclick="window.open(this.href);return false;
The button is in the handy custom panel.
all you have to do is to edit the button and add at the end "Set Keystroke-> Layer-> Clear"
You can also assign the button to a keyboard shortcut.
tangofish
Post by tangofish »
Hi furushil,
aaahhh, awesome! Got it. Thank you!!
But how do I assign a keyboard shortcut to the button?
furushil
Post by furushil »
The button is called "break instance" so you can just search for "break instance" in the shortcut panel. It is under "handy custom panel".
I think it should work that way.
break instance.png (87.84 KiB) Viewed 9459 times
tangofish
Post by tangofish »
Whoaaa! Works perfectly.
Thank you so much for your support. I was really devastated when I thought there's no chance to make my beloved shortcut work in TVP 11. You made my day! :)
