Postproduction process. Shadows and highlights
To talk about anything else
AlexanderNN
Post by AlexanderNN »
Hi :) im curious about the shadows and highhlights process . How exactly should i make shadows/highlights in my postproduction process ?
How is made that Klaus movie , wich in my opinion is great piece of art :)
Re: Postproduction process. Shadows and highlights
Unfortunately I can't tell you the answer, since I'm working completely different, but maybe you post this question in technical support and someone will help you
AlexanderNN wrote:Hi :) im curious about the shadows and highhlights process . How exactly should i make shadows/highlights in my postproduction process ?
Hmmm .. what style do you want to achieve ?
ten_zero
Post by ten_zero »
AlexanderNN wrote: How is made that Klaus movie,
Perhaps so : like Sergio Pablos〝Klaus〟theaser (made with TVPaint) at Annecy 2015, right ?
Sergio Pablos Talks About His Stunning Hand-Drawn Project ‘Klaus’ [Exclusive]〟 Cartoon Brew
  • - Can you talk about your approach/process to lighting and texturing the piece and the type of challenges presented to achieve this look?
    •  I can’t go into too much detail, but I can tell you that no geometry is involved, that the end result depends greatly on the artistic ability of the creators, and that it mostly takes place during the later stages of production, which means that it does not affect the way in which traditional animators work.
    - How many animators were involved in making the piece? And do you (and others at your studio) still animate on paper or do you draw everything digitally?
    •  We had some friends around the world chip in with a few shots, but it’s mostly the work on two animators. Most of the animation was done digitally on TVPaint.
It seems to simulate "SSS (Subsurface Scattering)" coloring technic like "Team Fortress 2" or using 〝matcap shader〟 Post Process Effects.
TVP 11 Professional edition CTG layer or TVP multiple FX post effects - toon shading "millefeuille" may help you when you try it.
For more traditional hand-drawn shadows , these tutorials are very useful -
CREATE THE SHADOWS OF AN ANIMATED CHARACTER (TV PAINT) -
https://youtu.be/O5nbzEE6XFM
A Beginner's Guide to Drawing Shadows in under 6 Minutes
https://youtu.be/CROFvtosxOQ
https://www.youtube.com/watch?v=fl9alTw8gqc
Here's a more advanced method using animated masks in After Effects -
https://youtu.be/XvaxQpn2wYo
A longer version of the After Effects tutorial above -
https://youtu.be/Pxzs0PsK6Zs
This tutorial shows another way of making shadows in After Effects. The character animation was made in TVPaint , then transferred to AE to add
the shadows -
https://youtu.be/BI1Y5hgISSE
