HSV Color Disc
neonnoodle
HSV Color Disc
Post by neonnoodle »
Dear TVPaint team,
I would desperately like to see this type of wheel implemented in TVP:
(the picker above is from the open-source software MyPaint, and is also found in another open-source application, Krita.)
While TVP 11 now has the chromatic wheel, there is a great advantage to the color disc type of picker. With this type of picker, it is possible to visualize the gamut or colorspace that is encapsulated within a certain area of the color wheel:
The colors inside that triangle are harmonious and related to each other in the gamut. No matter what the lightness slider does, all the colors in that area will still be in the scheme.
In a traditional painter's wheel, complementary colors are across from each other on the circumference of the disc, with the neutrals in the center as intermediate colors between them:
With the TVP color picker box, it's possible to see the intermediate neutral colors, but they are flattened and distorted into a square (sort of like the way the globe of the Earth becomes distorted when flattened into a square map):
Re: HSV Color Disc
It's already "TODO listed" with many other improvements of the color panel, but I can't give a release date.
neonnoodle
Re: HSV Color Disc
Wonderful! So glad to hear it.
