cannot export quicktime with alpha (again) Topic is solved
I had this problem before:
viewtopic.php?f=40&t=7055&p=63651&hilit ... pha#p63639" onclick="window.open(this.href);return false;
when exporting a project as a h264 QT with alpha (no Background) the quicktime on reimport has a black non transparent background?
see image
the two top layers are the reimported QT's
one multiplied and one pre-multiplied.
the only difference i saw was that when exporting in pre-multiplied mode you get to see the checker pattern. in non-premultiplied it looks black.
tvpaint-alpha export.png (97.57 KiB) Viewed 16882 times
Re: cannot export quicktime with alpha (again)
ARgh i have it again...
Help.... alpha export doesn't work, again.
forgot what fixed it last time, i'll do a restart... :-(
H.264 is a codec which doesn't support alpha.
Codecs which support alpha are:
- PNG (with millions+ colours checked)
- Apple ProRes
Don't forget to choose RGBA in the export panel.
Ah darn.
Dank Langsame Tiger, i didn't now about that h264 limitation!
i think TVPaint should issue a warning when trying to export RGBA with a codec that doesn't support the A
Quicktime is not managed by TVPaint : what's happening in Quicktime cannot be detected by TVPaint.
should be fixed next build 11.0.7.
