Simplest question ever...
chrisheadrick
Post by chrisheadrick »
....but it drives me nuts!
Every once in a while--about once a year--I hit the wrong button on the keyboard and make my default white background disappear globally, replaced by the 'checkerboard' alpha channel pattern.
How do I get my white background back, globally? Without it, I have to constantly lay down a white layer in the background of every project, which is maddening!
Thanks! C
Re: Simplest question ever...
SHIFT B
is the default toggle for this
function is called "layer toggle background mode" if you want to assign a keyboard shortcut (CTRL-K)
oellen
Post by oellen »
If you don't want to learn another keyboard shortcut (and remember it until next year), there is a little menu at the bottom left of the layer menu that says "background." You can choose your background there "color" "checkboard" or "none".
Cintiq 27 QHD
TVP 11.5.1
chrisheadrick
Thank you thank you! About once a year, I must hit SHIFT B by mistake!
ematecki
Post by ematecki »
If you never use the Shift-B shortcut, the best thing to do is go to the short-cut panel, and unassign it...
