How to desable stroke animator
marylou
Post by marylou »
when going in preferences, i can't uncheck animator stroke is this normal ?
Screen Shot 2015-09-28 at 14.05.30.png (28.59 KiB) Viewed 30071 times
Re: How to desable stroke animator
It is unchecked.
Mads Juul
Post by Mads Juul »
marylou wrote:when going in preferences, i can't uncheck animator stroke is this normal ?
It look like the checkbox is missing.
It looks like some kind of misbehaviour/bug to me. I have never experienced this
Oh god, yes you're right ! I just thought the checkbox was not visible but still checkable :shock:
Marylou, are you using the Standard Edition on Mac ?
marylou
Post by marylou »
it seems unchecked but it's still activated.
as Mads said, it looks like a bug, any chance the TVP team know about it and how I could fix it ?
haha we are quite tired at the studio to hit ctrl instead of alt and have an animated stroke to undo :)
tanks a lot for you quick reply as usual !
marylou
Post by marylou »
Elodie wrote:Oh god, yes you're right ! I just thought the checkbox was not visible but still checkable :shock:
Hi Elodie, we are indeed using the standard edition on mac ;)
Mads Juul
Post by Mads Juul »
Have you tried a new configuration?
marylou
Post by marylou »
a new configuration ? as in on another operating system, another machine ?
the same bug is happening with the 3 mac we installed it on
Mads Juul
Post by Mads Juul »
On Windows OS computers if youhold down the SHIFT Key when starting TVPaint
this popup will appear
Where you can choose to create/Reset the tvpaint configuration
I don't know if it is tthe same on mac.
But you can also enable the startup panel in the Preferences
But since you say You have installed TVPaint on 3 different computers, it doesn't sound like it can be solved by resetting configuration
-Mads
Here it has nothing to do with the config, it is a bug or something.
marylou
Post by marylou »
Thanks Mads, I will try !
marylou
Post by marylou »
Elodie wrote:Here it has nothing to do with the config, it is a bug or something.
yes indeed,you're right it didn't work, do you have any idea of what we should do ?
Wait for the 11.0.3 update, shouldn't be too hard to fix I think.
(or upgrade to the Pro Edition, but that wouldn't be fair for you...) :oops:
Mike
Post by Mike »
Bug happen only on MacOSX for Standard edition (and Pro 32bits)
The checkbox corresponding to "Stroke Animator" option is the one on the "Use OpenGL" line.
If you display the tooltip, you'll see it's about the "Stroke Animator".
Fix' in the next release.
TVPaint Team
