Quick question on animating
Posted: 11 Oct 2015, 04:47
Hey everyone, I'm new to animation.
When professional animators make a short-film using TvPaint, what is the drawing process for things that have motion that have a lot of detail and color and shading and stuff? Let me explain:
Let's say you want to animate an apple rolling from point A to point B. Are you supposed to sketch the animation frame by frame, then once that's done, GO BACK to the 1st frame, and go through each frame by frame coloring the apple red? Then once that's finished, GO BACK AGAIN to the 1st frame, and go through each frame shading it and giving it some shiny touches? (To make the apple more realistic, instead of flat).
OR
Are you supposed to make the apple look as it should all at once as you go along? Instead of having to go back to the first frame and go through the whole thing again.
Or is there an easier way to do this on TvPaint?
Thank you
OR
Thank you
