A and B colors (resolved)
oellen
Post by oellen »
Hi
I have problem with my color picker. When I start up TVP, and I choose a color it goes to the Color "A" position and whatever was in "A" goes to "B", which is the way that I like it to work. However, at some point while I'm working, TVP stops putting the new color in the "A" position and starts putting it in the "B" position. Then I end up making my first stroke with the wrong color and I have delete and swap the colors. How can I make sure that the new color that I pick always goes to the "A" position?
Thanks for the help.
Cintiq 27 QHD
TVP 11.5.1
Re: A and B colors
how do you use to pick your A color exactly ?
here, I've 2 ways (I use mostly the second one) :
1) LMB-clic into the A color spot (from the Color panel or from the Main panel),
you will get a "?" just behind the arrow cursor meaning "go and pick the desired color",
then clic on the color you want anywhere around into the tvpa interface,
2) use the ";" shortkey, (it's by default assigned to the "Pick Acolor" command,
then again, clic on the color you want anywhere into the tvpa interface,
Re: A and B colors
I never found a way to pick a new APen color and automatically have the old APen color assigned to the BPen color. That really happens to you?
Anyway, here's a short George Script that WILL do that when embedded in a button.
tv_GetAPen
OldAPen=result
tv_PicColor
parse result d NewAPen
tv_SetBPen OldAPen
tv_SetAPen NewAPen
But there is a way to use the SAME shortcut key to assign a clicked-pixel-color to APen or BPen:
Assign a shortcut key with Color:Pick shortcut command. When you press the shortcut key, a color-picking arrow appears.
If you click on a color pixel with the LMB (Left Mouse Button) the clicked color becomes the new APen color.
But if you click on a color pixel with the RMB (Right Mouse Button) the clicked color becomes the new BPen color. :D
Re: A and B colors
or, without scripting, assign 2 commands to your ";" shortkey, in this order :
Color: Invert A/B + Color: Pick
personnaly, when I need to retrieve the previous used Acolor,
I go to the historic colors palette (the little down-arrow in the main panel),
and pick in the pop-up palette the second one from the up-left corner.
(in fact, it's just a one clic matter).
oellen
Re: A and B colors
Post by oellen »
I'm just talking about picking a color from the color panel. When I first open TVP and I pick a color from the color panel it goes to the A color, but at some point (during the session) when I pick it from the color panel it goes to the B color. I have to shut the program down and reopen it to make it go back to putting the color from the color panel back into the A position. Maybe, it's something I'm doing with my cintiq pen, along the lines that Sven posted.
Cintiq 27 QHD
TVP 11.5.1
furushil
Re: A and B colors
Post by furushil »
If you click on the B color with the left mouse button and then use the color sliders, then you are picking the B color. If you click on the A color then you are picking the A color (when using the color panel).
Maybe at some point during your session you click on the B color?
Try to click on the A color field when it happens again.
Re: A and B colors
oellen wrote:I'm just talking about picking a color from the color panel. When I first open TVP and I pick a color from the color panel it goes to the A color, but at some point (during the session) when I pick it from the color panel it goes to the B color. I have to shut the program down and reopen it to make it go back to putting the color from the color panel back into the A position. Maybe, it's something I'm doing with my cintiq pen, along the lines that Sven posted.
I think I get it now. Your tool (pen, pencil, line or shape) uses the APen. Normally, you change the APen color by selecting from the color panel. But all of a sudden (and you're not sure why) the color panel colors you pick are being assigned to the BPen color, right? Your question is: Why does this happen... and How can you change back to having your color panel choices assigned again to the APen.
The simple solution:
If the color you are picking in the color panel suddenly starts getting assigned to the BPen color DON'T shut TVPaint down. Instead, simply click on the APen color. That tells TVPaint you want any future colors picked from the color panel to be assigned to the APen color again.
You are probably inadvertently clicking on the BPen color as you work, so TVPaint thinks you want all your future clicks to the color panel assigned to BPen. Not a bug, that's just how it works. So, click on the APen color and your color panel picks will be assigned to the APen color again.
color picker arrow.jpg (4.34 KiB) Viewed 24791 times
One other thing to know. If your color picks from the color panel are already being sent to the APen color and you click on the Apen color (or the eye-dropper next to it) you'll get an arrow cursor with a question mark - this arrow cursor lets you sample a new APen color from any pixel in your image or from any other place on the interface (including the color panel).
sven
oellen
Re: A and B colors (resolved)
Post by oellen »
Got it. Thanks!
Cintiq 27 QHD
TVP 11.5.1
