paper suddenly changed its color
oellen
Post by oellen »
Hi
I'm having a sudden strange problem with paper. What I have been doing for hundreds of frames is making a selection filling it with the paint bucket with a solid color without paper. Then I fill the same selection with a darker color with paper. Everything was working exactly how I wanted it to, until all of a sudden the results of the second fill color while using paper became much darker. See images
Results that I want
Results that I want
color 1.jpg (15.3 KiB) Viewed 14481 times
Wrong results
Wrong results
color 2.jpg (14.47 KiB) Viewed 14481 times
I want the lighter results. What did I do wrong?
Cintiq 27 QHD
TVP 11.5.1
Re: paper suddenly changed its color
Can you post a screenshot of the interface ? It's difficult to answer as there are many possibilities.
Possible mistakes:
- wrong colour chosen
- wrong colour mode chosen (like multiply)
- fill opacity changed
- layer opacity changed
- paper strength changed
oellen
Post by oellen »
Here are two screen shots from step one to step two. I will also check all the other stuff you mentioned
First fill without paper
Second fill with paper
Cintiq 27 QHD
TVP 11.5.1
Animark
Post by Animark »
It's just an idea of another possible mistake:
Maybe you have filled the area accidentally a second time with the darker color.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
oellen
Post by oellen »
Well not quite sure what the problem was, but I reset my paint bucket and everything seems ok now.
Cintiq 27 QHD
TVP 11.5.1
I would advise you to record a video of the process, with the whole interface.
