I can't seem to be able to get the sound to play back in the export. It all plays fine in the program, but it's just silent in the export... I need to present it to a client in a few hours :S
https://drive.google.com/file/d/0BxEk8T ... sp=sharing" onclick="window.open(this.href);return false;
I've tried exporting it as a .mov too, but no luck still.
Sound problem I need a fix for ASAP
http://www.daninski.com
Re: Sound problem I need a fix for ASAP
I assume the issue is from MP4 / MOV, which depends on FFMPEG libraries, which is currently being fixed.
Use the AVI format or install the 32 bit version of TVPaint to enjoy Quicktime codecs.
Oh I see.
Ok, thanks.
Ok, thanks.
Ok great, that worked. Thanks.
You"re welcome
Also keep in mind that once you have exported the animation from TVPaint 64bits version to a .AVI file , if you have Quicktime 7 Pro you can convert the .AVI file into a Quicktime .mov file with standard Quicktime compressions like H.264 or Apple Pro Res (it all depends on what Quicktime .mov codecs you have installed on your computer).daninski wrote:Ok great, that worked. Thanks.
See: viewtopic.php?f=10&t=9376&p=86521#p86485" onclick="window.open(this.href);return false;
I tend to use Handbrake if I want something quickly. Really nice and free.
Although I do have compressor for the pro rendering.
Hey, thanks for the tip! I've been looking for video conversion software like that.daninski wrote:I tend to use Handbrake if I want something quickly. Really nice and free.
Oh, yes, Handbrake is good , too. I tend to use Quicktime Pro 7 a lot because it's so fast and simple to use , but Handbrake has more options for fine-tuning the compression / streaming bitrate/ sound sampling rate, etc.daninski wrote:I tend to use Handbrake if I want something quickly. Really nice and free.
