Example for a Hue Stamp Brush?
Posted: 04 Nov 2015, 15:32
Definition of the words I use (For better understanding.I hope they are correct.):
Stamp: That's what the brush is made of - the pixels in the brush
Print: That's what the brush is printing on the "paper"
OK, here is my problem:
I try to analyse how the Hue Stamp brush-Setting is working. I understand, that the brush-setting is based on the H-Values in the HSL Slider. I made some tests with different hue-values but only got a solid colored print of the brush. Also mixing different colors with different H-values in one stamp only results in a solid color print (the A-Pen Color). Using gradients between different colors (different H-values) just makes the prints a greyish, where the colors are mixed together.
The explanation in the manual says: "Hue Stamp : uses the A color but keeps the hue." [chapter 11]
Mhm?
Maybe it helps me to get a better idea of the Hue-Stamp when having a good example. Is there a brush using the Hue-Stamp setting with any result that is not possible to get with one of the other brush-modes? The worlds most famous very unique Hue-Stamp-Brush?
Many thanks in advance!
Mhm?
