Right click doesn't work
Shunsuke Saito
Post by Shunsuke Saito »
I'm using a tablet PC called Vaio Z Canvas, which is like Surface series from Microsoft.
Detail of the PC here
http://www.digitalartsonline.co.uk/feat ... ographers/" onclick="window.open(this.href);return false;
This PC also uses N-trig technology like Suface.
I tried it with TVpaint it works fine except for one thing.
Right Click doesn't work with the Pen. It works fine with track pad.
When I press right click button nothing happens.
I tried both with "Ink" and "Wintab" but neither of them worked.
Since TVpaint uses Right Click to zoom the canvas and the shortcut cannot be changed, it is really frustrating.
I hope there are some ways to solve this problem or work arounds to zoom without using Right Click button.
I'm using Windows 10 and 64bit version of TVpaint.
Thank you.
Re: Right click doesn't work
It sounds like Windows doesn't allow to assign the right click to a N-Trig stylus button, nor a keyboard key to a N-Trig stylus button. Sorry for the inconvenience.
Something you can do is assign the right click to the space bar for exemple :
Animark
Post by Animark »
I think I had the same issue some days ago with my wacom companion. If I remember correctly I found a setting in the options of the wacom driver, where you can choose between "Hover Click" and "Click & Tap". After I choosed "Hover Click", the right click option in TVPaint worked as expected. Give it a try. (OK, I am not sure if your tablet uses Wacom-Technic. If not, maybe there is a comparable setting.)
Here is a picture of the options I found somewhere in the internet:
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
I dislike being negative, but N-Trig and Wacom are two different technology.
It's worth trying anyway. :)
