Adding more Feat/Control to the Chrom Wheel'Lock Degree,Etc'
Posted: 04 Dec 2015, 08:02
by TheQuestionMark
Is there way you can lock your 'angle ?' degree of your color wheel, the small circles? There are sometimes when I click the it shifts and lose the accuracy of the degree that a really like. I get really shaky for when I lose the color accuracy.
Also is there way you once you set up your locked degree of your color wheel and save it as presets of it maybe 4? or I can see it this way. At the Top Left Side '-' Symbol and the Bottom Left a '+'. And there's a scroll bar that you can add much preset as you like. I guess the name will be numbers?
Also is there a way to add hot keys to the color wheel to hop into the smaller circles. I think it's up to 3 right? That's something photoshop doesn't have even the paid color wheel of photoshop as well.
Also there you can tweak the cursors inside of the color wheel? I think it's needs a 'point in the center' as well to get more color accuracy, in all of the circles of the color wheel.
Another thing is to add is I think a 'degree' measurement beside the R:### G:### B:###.
Re: Adding more Feat/Control to the Chrom Wheel'Lock Degree,
Posted: 04 Dec 2015, 10:25
by Fabrice
lots of interesting ideas here. But we need more screenshots. :)
Here :
Also, I'm unsure of this :
what do you mean exactly ?
you can click on it and switch to HSL, so you have the current degree. Or did I misunderstood ?
Posted: 04 Dec 2015, 16:44
by TheQuestionMark
Fabrice wrote:lots of interesting ideas here. But we need more screenshots. :)
Here :
Adding a Hotkey hop into the Smaller Circles of the Color Wheel and switch to that color. When you select by mouse, the Hue of the Color Wheel, the big circle moves to it, you then want move and switch color to the smaller circle by hotkey. I think switching color to the smaller circle by hotkey is more color accurate.
I think it's a misunderstood I think.you can click on it and switch to HSL, so you have the current degree. Or did I misunderstood ?
Here's the Diagram.
http://i.imgur.com/br5DqzJ.png?1" onclick="window.open(this.href);return false;
I hope it's makes everything clear.
There maybe a switch around of the '-' or '+' Button position. I'm not sure which is the best arrangement to avoid accidental deletion of the presets.
Yes, I like looking at other people's illustration and eye dropping to color analyze/study the position spots on the color wheel. I think having an extra degree measurement helps me understand more about how color of certain illustration work, and more accurately, also may help me on my own works too.
Posted: 05 Dec 2015, 22:28
by Fabrice
thanks !
