Playback without Camera View : View finder and follow active
I would like that it was possible the Camera View finder(A) and the Camera Follow(B) is active during playback(C) when "Play with the camera view"(D) is Disabled.
I want the playback to look as the canvas when I'm scubbing in the timeline and Viewfinder and follow is active.
I guess the implementation of this feature request is relatd to this:
http://forum.tvpaint.com/viewtopic.php?f=21&t=9598
Kind regards Mads Juul
Is this clear what I mean?I want the playback to look as the canvas when I'm scubbing in the timeline and Viewfinder and follow is active.
- NathanOtano
Re: Playback without Camera View : View finder and follow ac
I really need that too
- schwarzgrau
And I would like it
Let's add this to the to-do list then !
Cool! Thank you
But if you play with "camera view on", you will see the camera view, so you cannot see the view finder...
Correct.Elodie wrote:But if you play with "camera view on", you will see the camera view, so you cannot see the view finder...
This is why my topic is "Playback without Camera view..."
And I wrote in the first post that Playback with camera view(D) should be disabled
The camera view and the camera viewfinder is two opposite things, which combined is the canvas.
The Camera view is what the camera sees and the camera view finder is what is outside the camera (called passe partout before)
When the camera viewfinder is enabled in the display panel a color is appearing on the canvas to indicate whaat is outside the camera.
It is this color I would like to still see if I choose to playback(preview) without "Playback with camera" view enabled. in this playback the entire canvas is possible visible and there for it is possible to see the color of the camera viewfinder so I can see my composition and what is inside and outside of my camera during playback.
Kind regards Mads
By the way this is the way it is playbacked in toonboom storyboard pro.
Byt in toonboom storyboard pro is is not possible to set the opacity of the Viewfinder(Passepartout) it is always 100%
Yes. That's what happens when you read forums at 6-am7am on the busAnd I wrote in the first post that Playback with camera view(D) should be disabled
I remember you asked it earlier, maybe 1 or 2 years ago.
> to do listed.
Re: Playback without Camera View : View finder and follow active
Has this feature requests been implemented?
Best Mads
Best Mads
