A way to know if an instance is empty?
NathanOtano
Post by NathanOtano »
Yop
I searched on the forum but haven't found it.
Is there a way to know if an instance is empty with george?
Nathan
EDIT : Ok, found a way using a cutbrush, thanks Svengali : http://forum.tvpaint.com/viewtopic.php? ... box#p73598" onclick="window.open(this.href);return false;
Re: A way to know if an instance is empty?
Another strategy (probably faster and perhaps easier to incorporate in a looping test of all Instances on a layer) is to write a script around the following:
tv_layercompareimage LayerID1 ImagePosition1 LayerID2 ImagePosition2 //compares two specific layer/images to discover "sameness"
Which compares the Instance in question with a known blank Instance.
NathanOtano
Thanks!
When using image mark panel, you can assign a colour for empty instances.
NathanOtano
Elodie wrote:When using image mark panel, you can assign a colour for empty instances.
But i can't automatically asign an image mark to all empty instances, right? I have to detect which instance is empty before that.
Yes it does ! :)
NathanOtano
Haha awesome thanks. Never saw that
Is it available for keystrokes or George?
I don't know :s
I don't think it exists in George.
And there's no shortcuts for this too.
Feature request ? :p
NathanOtano
I would prefer a simple "is empty" George comand (maybe related to the get bounding box request from MJ) rather than using image marks :)
I don't often need to mark every empty instance with a color (I would Irefer to MARK all used instances with a color in fact). I use image marks for a lot of other specific things when I animate.
So you want me to create another topic specifically for this keystroke request? :)
