Opacity slider in group panel
NathanOtano
Post by NathanOtano »
I would like an opacity slider in the group panel. To set the opacity of all the layers in a group at once.
Nathan
Re: Opacity slider in group panel
This makes sense in the case all layers inside have the same opacity settings, but what happens if these are different - maybe I want to keep it that way?
NathanOtano
Same problem if you have some layers visible and others not. The panel acts as a global off/on switch regardless of individual layers and overrides all settings.
It basically would work the same. You use it only when a group of layers shares the same opacity intentions (ol, ul, characters, bg in a board for exemple)
NathanOtano
Just wanted to up thread again. I'm encountering everyday the need for this functionality, if for exemple I have a group for OL/UL/Anim/BG and I want to set the opacity of one of the groups to work on another. It's different from the layer attenuation functionality cause I often need to work on multiple layer at once with the same opacity.
Or maybe the layer attenuation function could have a "current group" parameter, that permits to extend the attenuation to the current group instead of current layer.
Just discovered this thead. A +1 from me.
momo
Post by momo »
big +1
momo
