Importing 2 TVP projects into one master TVP project
Posted: 11 Feb 2016, 16:29
by JQuinn
Hello clever people,
I am trying to import a few 2 TVP projects into one new project but I can't seem to work out how. The projects I want to import are 2 scenes that follow on from each other and I want to see them running together. I thought it might be via the project tab used for storyboarding but without much joy. I've checked the tutorials and this forum but can't seem to find the answer. Any advice would be appreciated.
Thx
Joanna :shock:
Re: Importing 2 TVP projects into one master TVP project
Posted: 11 Feb 2016, 16:47
Open both projects. Go to project view in both.
In source project, select the clip you want to copy (RMB, "select clip"), then copy (cmd-C).
In target project, RMB into clip and select "paste after".
Save.
Posted: 11 Feb 2016, 17:26
by JQuinn
Thanks. I've followed your instructions and I now have the 2 clips in the project area but when I go to the timeline it only shows the selected clip. How can I show both clips in the timeline? thx
Posted: 11 Feb 2016, 17:46
You can only see the content of one clip at a time. You can, of course, in project view have both clips play back continuously.
If you need to have the content of both clips in one, there's only the way to copy the frames layer by layer, I'm afraid. (Maybe this could be scripted? Maybe someone already did?)
Posted: 11 Feb 2016, 17:51
by JQuinn
ok thanks for your help. Hmmm plan B....
Posted: 12 Feb 2016, 09:34
slowtiger wrote:If you need to have the content of both clips in one, there's only the way to copy the frames layer by layer, I'm afraid. (Maybe this could be scripted? Maybe someone already did?)
There is a button for this :)
merge clips.mp4
(2.04 MiB) Downloaded 1141 times
Posted: 12 Feb 2016, 10:45
I never even noticed this one!
Posted: 12 Feb 2016, 11:09
by schwarzgrau
Me too. Maybe someone should create a new "Conten sharing" topic, with all the scripts, brushes etc. If it's ok I would try to create such a topic and extend it over time.
Posted: 12 Feb 2016, 11:38
by JQuinn
Oh great thx Elodie!
Posted: 12 Feb 2016, 11:39
by JQuinn
Sounds like a good plan @schwarzgrau
Posted: 12 Feb 2016, 13:06
slowtiger wrote:I never even noticed this one!
Such a useful tool , but so easily overlooked . Like many of TVPaint's useful tools it remains hidden until discovered through a post such as this on the forum. Notably if you search the User Manual for "Merge Clips" or "Merging Clips" or "Merge Clip" there are no results. Where it is found is under "Changing Clips or Scenes" . http://www.tvpaint.com/doc/tvp11/index. ... age-change" onclick="window.open(this.href);return false;
This is another argument in favor of a pdf version of the manual , because a PDF is much more searchable by phrase or word. In the PDF of the TVPaint 10 User Manual a search for "Merge Clips" finds it immediately. But if a PDF is no longer practical , then the search engine for the online documentation needs to be improved.
Posted: 12 Feb 2016, 13:27
by JQuinn
Brilliant thanks!
Posted: 15 Feb 2016, 09:31
by Mike
D.T. Nethery wrote: Such a useful tool , but so easily overlooked . Like many of TVPaint's useful tools it remains hidden until discovered through a post such as this on the forum. Notably if you search the User Manual for "Merge Clips" or "Merging Clips" or "Merge Clip" there are no results. Where it is found is under "Changing Clips or Scenes" . http://www.tvpaint.com/doc/tvp11/index. ... age-change" onclick="window.open(this.href);return false;
Now, when you search inside the online documentation:
_ if the exact search text is found, no problem
_ if the exact search text is NOT found, search again through every words of the text
