command to toggle Stencil's checkerboard visibility
Is there a GEORGE command that lets you toggle the Show Stencil checkerboard on and off?
If not, I'd like to request a command that lets you set the Show Stencil checkerboard area on/off AND control its transparency.
Perhaps something like this:
tv_ShowStencil ["On"|"Off"] [Opacity val]
Used this way:
tv_LayerStencil LayerID On Normal // existing command to activate a layer as a stencil
tv_ShowStencil On Opacity 20 // show checkerboard at 80% transparent
OR
tv_ShowStencil Off // shut checkerboard off
OR
tv_ShowStencil On Opacity 100 // show checkerboard at 0% transparent (totally opaque)
thanks, Sven
Mike
Re: command to toggle Stencil's checkerboard visibility
Post by Mike »
tv_display stencil on|off
But no parameter to toggle or set the value or set the color
TVPaint Team
thanks, that is useful. :D
A Request then:
(1) make the Stencil color and opacity settings be remembered between sessions
(OR)
(2) make the Stencil color and opacity set-able in the tv_Display Stencil parameters
And Another Stencil question as well: If a stencil is in effect on two layers, shouldn't the stencil checkerboard show for BOTH layers since they BOTH affect where you can draw on other layers?
