Weird TvPaint Reset Leading To Broken File? (Solved)
Posted: 29 Feb 2016, 23:07
by Bop
Hello! I have TVPaint 11 Standard, version 11.0.2, and it's downloaded on a 64 bit Asus EEE Slate EP121 Tablet PC. I have Windows 7. Since my tablet is a little old, sometimes the stylus disconnects from the tablet and doesn't work right, so I turn my tablet off and back on. I did this recently, making SURE to save my Tvpaint file before I quit, but when I booted my tablet back up again, Tvpaint was acting strange. I didn't think to get any screenshots, but the workspace had seemed to be completely reset itself, and the strangest thing was that the color wheel had shrunk in size and I couldn't fix it.
At this point I couldn't open any files. I removed the dongle several times before finally manually resetting the workspace, returning the color wheel to its normal size again. I could open every file but the one I had open (and clearly know I saved and quit the program) when the stylus went out of whack. Whenever I open the file, Tvpaint becomes unresponsive. I've heard that if a file gets corrupted you get a message that says "Bad File"? Is this the file or the program? Is there anything I did to prompt this reset? Does anyone have any ideas?
- File in question
Re: Weird TvPaint Reset Leading To Broken File?
Posted: 01 Mar 2016, 07:23
Hello Bop, that's a weird behaviour, indeed !
Have you tried to reset your config ? To do so, when opening TVPaint, hold "Ctrl" to display the Starting panel. You can reset the config here by hitting "delete".
http://www.tvpaint.com/doc/tvp11/index. ... nces-start" onclick="window.open(this.href);return false;
Then, try to open your file.
Posted: 01 Mar 2016, 22:39
by Bop
Thank you so much for responding.
Unfortunately, it didn't work. Every other file is working, I don't understand what's wrong. Should I send you the file?
Posted: 02 Mar 2016, 08:23
Could you then us the file so we developers can check what's wrong ?
Posted: 02 Mar 2016, 23:15
by Bop
For some reason it won't let me attatch it onto this post either! What a nasty file!
Would you like me to send it by email instead? If so, which email?
Posted: 03 Mar 2016, 07:38
Probably because it's too big
Send it by wetransfer to Thierry (tcantet[@]tvpaint[.]fr)
Posted: 03 Mar 2016, 22:51
by Bop
Okay, I sent it! Thank you so much.
Posted: 04 Mar 2016, 09:09
by Thierry
I've recieved your project.
I'll forward to the developpers so they can try to recover some data.
Posted: 04 Mar 2016, 10:29
by Thierry
We did manage to recover some data, but not a lot, as most of it was lost.
You should have recieved a link to download what we were able to recover.
Posted: 04 Mar 2016, 22:41
by Bop
Thank you, even this much helps! You gave me much more than I expected, thank you again!!
