Make those tool tips go away!! [Solved]
- David_Fine
So I know there is a simple solution to this, but can I find it? NO!! I am getting those large tool tips which pop up whenever the pointer is held over something. It's annoying and I want to turn it off, but I can't find anything in prefs to do this. Where is it? Why can't I find it? Is it me?? Help!!!
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
Vancouver, Canada
Re: Make those tool tips go away!!
Oh my god I know the answer!!! My first bit of advice! Go to Top Menu>Help>Tooltips> choose none. Woo hoo!!! I must be a professional now!
Mr. Fine,
- Have you got the information in OS X Menu bar "Help" menu ?
Perhaps your TVP.app requied to change "None".
I told you it would arrive sooner than expectedJQuinn wrote:Oh my god I know the answer!!! My first bit of advice! Go to Top Menu>Help>Tooltips> choose none. Woo hoo!!! I must be a professional now!
- David_Fine
Re: Make those tool tips go away!! [Solved]
Joanna, you did it!! Thank you. I knew it would be painfully obvious once I was told, but having said that, I wonder why that setting is in the Help menu instead of Preferences under the interface tab? I searched for "tool tip" in the manual but nothing turned up because you need to search for "tooltip". Doh!
David Fine
Vancouver, Canada
Vancouver, Canada
Because "tool tip" is not common words in French and Japanese ; in case of "langage barrier" why Comtuper Software localize be carefuly.David_Fine wrote: I knew it would be painfully obvious once I was told, but having said that, I wonder why that setting is in the Help menu instead of Preferences under the interface tab? I searched for "tool tip" in the manual but nothing turned up because you need to search for "tooltip". Doh!
If TVPaint English mode "tool tip" culturized "Balloon / pop-up help", you might seek "Help" command list in menu bar at first.
