Exporting instances
Posted: 17 Mar 2016, 09:17
Hi,
Is it possible to export image sequence from the new instances or bookmarks?
M.
M.
TVPaint boards for technical support, requests and discussions about animation.
http://tvpaint.org/forum/
I mean I need only the first frames of the instances as exported frames. Not exposures. I know the work around by merging the layers and set exposures as ones and then export the sequence. But just thinking is it possible set export only for the "new frames".Elodie wrote:I don't get "from the new instances".
From bookmarks, it's not possible either, since you can have several bookmarks.
